Author Topic: amos craft  (Read 4172 times)
matbas
amos craft
« on: June 14, 2007, 03:33:39 PM »
Can anyone tell me what Amos Craft is and which version of Amos it is compatible with?
Re: amos craft
« Reply #1 on: June 14, 2007, 08:20:47 PM »
According to the Amos Extension List it is an extension either for Amos or AmosPro by Black Legend.  I don't know what it does though.
Re: amos craft
« Reply #2 on: October 20, 2007, 10:34:41 PM »
I should really get around to updating the details sometime.
*digs out CRAFT*
Ok, according to the manual you can:
 - Store Palette data in a bank (eg. you can store multiple palettes in one bank, or in multiple banks)
 - Alter Red/Green/Blue values of active colours
 - Use new System Requestors & Guru messages.
 - Load and play Sound/Noise/Protracker modules
 - Create Fractals/Mandelbrots very fast & easily
 - Draw using a LOGO style "turtle".
 - New string functions
 - New memory commands (eg. find largest amount of continous memory)
 - New disk commands
 - Useful CLI commands (eg. can tell whether a CLI is presently active)
 - Alter AMOS priority (eg. give it more CPU time than other programs)
 - 2 commands to reset the Amiga - Hard Reset and Warm Reset (the latter leaves data in RAM intact on resetting!)
 - Misc commands (eg. Wait Beam Y (wait for Raster beam to reach Y position).
I hope that helps you.
