Author Topic: amospro help files  (Read 3327 times)
rednova
    • http://www.feryogi.com
amospro help files
« on: August 26, 2007, 06:26:52 PM »
Hi Skate:
I have the same problem. My amospro installed to hd, and it can't find the help files.
What you can do..is to load the help files direct from disk...anytime you need them.
Hope this helps.
rednova
-mobilis in mobile-
Re: amospro help files
« Reply #1 on: August 26, 2007, 06:47:48 PM »
is it not just a matter of setting up an assign?
« Reply #2 on: August 26, 2007, 08:59:44 PM »
I've had this problem before and fixed it pretty easily from what I can recall, but now I can't figure it out. I think I will just reinstall AMOS PRO, since my current install is almost an exact copy of horace's setup, which means that the drives and assigns are not set up for my system.Now to download all those disks! O_O
« Reply #3 on: August 27, 2007, 01:21:31 AM »
the help files have never worked on my install anyway, and i am pretty sure its becasue i havent set up any assigns to replace the floppy disk names
i did tell you to install properly skate ;)
« Reply #4 on: August 29, 2007, 09:03:49 AM »
hehe, well you know me, just plain lazy. ::) I suppose I will go download all 9+ disks and do it poroperly, just need to eat some sugar so I can stay awake during the install  ;D
« Reply #5 on: August 29, 2007, 08:03:28 PM »
JIT on, high CPU & memory, and turbo-speed ADFs.... id be more worried about the crapness of the installer if i were you ;)
« Reply #6 on: August 29, 2007, 09:41:14 PM »
you better be talking about the software installer and not the human installer  :D
« Reply #7 on: August 29, 2007, 11:05:29 PM »
lmao, no comment  :o
« Reply #8 on: September 01, 2007, 01:20:35 AM »
Lol.
Great to see you guys having fun here. I think this is my first message here (?), but I have been a member for a few weeks.
I never use the AMOS help files, instead I have both manuals (AMOS - TC and AMOS Pro) by my side when programming so I can check syntax and/or look up new commands (after all I can't remember all 500 + those from extensions!).
PS. Have you guys been downloading the AMOSlist archives I have been uploading to Aminet? If not, why not?!!
