Author Topic: Copper Play [Code]  (Read 3001 times)
Copper Play [Code]
« on: September 28, 2007, 08:45:28 PM »
Just thought we should start a thread with copperlist examples and such.
Here's how far I have got so far. Unarchive the LHA file to get to my "Copper_play.AMOS". Simple comment out the appropriate "Goto's" at the start of the file to select which one you want to view (didn't have time to create an option screen). Comment them all out to see the rainbows I created. When it ends you will have to press Escape, Control+C, Control+C and repeat until you get the copper back. Alternatively, scroll to the end of the first copper section (before AMOSCOP:) and add a "End" after the "Copper On" command.
Yes, strangely enough Copper On doesn't switch it back on when you are in AMOS Editor/Direct mode. Only "End" does that, or pressing Control+C when in Direct mode.
Re: Copper Play [Code]
« Reply #1 on: September 29, 2007, 08:37:42 PM »
Ok.
Now I will post decent copper code! :)
I have solved all problems today, bar 2 - I can't seem to get a full screen copperlist working (only 4/5's of the screen are used) and I haven't got the mouse working yet (but then I haven't tried!).
Enjoy the code. Run it and relax. You can only Control+C back to the editor (or flick workbench into view) when my copperlists *are not active*. The title screen is the best place to get back into the AMOS editor.
Copper Play v2.1
(Edit: Just added the easy to spot download button! - 23 March 2008)
« Last Edit: March 23, 2008, 11:14:38 PM by Lonewolf10 »
