Author Topic: Amos Group project  (Read 6815 times)
rednova
    • http://www.feryogi.com
Re: Amos Group project
« Reply #15 on: April 29, 2008, 10:14:57 PM »
hi all:
Samcrow: I have good news, about the modelling. Any model I make in lightwave, you can specify the height/width when you render. You can 'custom' size it. Ex. I make a beautiful robot in modeller. before you render a pic or anim, you can size it anyway you like, whatever size you like. The only difference is that you can render high quality or low quality according to your needs. Ex. You need a single frame high quality? then you can render that. You need a nice cinematic cut, but it has to be small in file size? render a lower poly scene, is good enough but it does not need lots of space/ram. You need a small 'robot'
only 50x50 pixels? You can custom size it anyway you want. www.feryogi.com
It has my mecha robot in the page -made in lightwave-. I can prob make nice robots, original and different ones.
Hope this helps!!!
rednova
-team amos-
-mobilis in mobile-
rednova
« Reply #16 on: April 29, 2008, 11:14:32 PM »
Hi all:
http://www.feryogi.com/m2meka001.jpg
that is the robot I modeled in lightwave.
Hope you like.
rednova
-mobilis in mobile-
-mobilis in mobile-
« Reply #17 on: April 29, 2008, 11:27:49 PM »
That sounds good, Rednova.  Could you render a 32x32 pixel picture with a camera angle 3/4 overhead (a 45 degree off of vertical) perspective in greyscale please?  I'm going to put together a loose prototype of the way that the screen is supposed to look in AmosPro sometime this week.
rednova
« Reply #18 on: April 29, 2008, 11:56:56 PM »
Sam :
I can do as you say. I will spend this week polishing my robots.
Cheers!!
rednova
-mobilis in mobile-
« Reply #19 on: April 30, 2008, 08:47:37 PM »
Rednova, that last comment sounds a touch dodgy! :o
It's good to see that this project has already started. I know I'm not a regular visitor to this forum, but I am about and usually contactable via email or Y! messenger (ID: aliensrcooluk).
