Author Topic: Hi  (Read 4565 times)
T34
Hi
« on: April 25, 2008, 05:00:46 PM »
From T34
New To PCs and The Web
Good at AMOS CODE
Demo out Soon off my NEW GAME
3 years of code to get the DEMO running
Wargame
I will send it to AMIGA FUTURE MAG
Don't no how to put it on the WEB
All HELP on how to use AMIGA FACTORY Please Not got a clue what im doin
« Last Edit: June 12, 2008, 10:29:56 PM by FOL »
Site/Forums Updated
« Reply #1 on: April 25, 2008, 06:11:12 PM »
@T34
To upload the game, just post it as an attachment to the "submissions" forum.  To get the "attach" function you have to click on the "Additional Options" link.  To expose the requester, click the "Browse" button by the Attach path gadget.
T34
Site/Forums Updated
« Reply #2 on: May 01, 2008, 09:02:31 PM »
Thanks, But how do i get my code from my amiga to the pc.
I need a step by step form amiga to pc . A step by step to upload the DEMO. Do i use lha. from my amiga then use a pc disk, to get the code into the pc. Sorry i just code amospro pc is new to me.
THANKs T34
Site/Forums Updated
« Reply #3 on: May 01, 2008, 09:54:38 PM »
You need CrossDos on your Amiga and a 720k PC disk.  Otherwise you may have to install a CF Flash memory reader in your systems but that is too complicated for now.
First do you have Amiga Workbench version 2 or better?
If so you must have CrossDos in Devs:dosdrivers/PC0 .  Just drag the icon from sys:storage/dosdrivers/PC0 to the other directory and restart the Amiga.
When you put a medium density disk in the Amiga, there should be two icons that appear:  DF0: and PC0: .
Click on PC0: and full format it there (not quick format).  Use LHA to compress any disk images you need to transfer since PC disks don't hold as much uncompressed data as an Amiga disk.
Copy it to the PC0: disk and use http://aminet.net/util/arc/lhant.lha to unpack the lha files on the PC.  Note: You'll have to decompress that file on the Amiga and transfer it over to the PC first.  It will run from the command prompt under Windows XP.
If you need more help, just post back here.
« Last Edit: May 01, 2008, 10:13:25 PM by SamuraiCrow »
T34
Re: Hi
« Reply #4 on: August 25, 2008, 02:28:40 PM »
My new game "DEAD METAL" Demo Done. Check The Next
AMIGA FUTURE mag 74. Might Be In The Mag. I"LL Send You a Copy
By Post What's Your Full Address.
                                                 With Thanks
        Col Butterworth
selur
Re: Hi
« Reply #5 on: September 03, 2008, 10:17:21 PM »
Hello T34
Please give a link to review of this game or upload it to the "Download" sections or put link with this "AMIGA FUTURE mag 74".
cheers
Re: Hi
« Reply #6 on: September 04, 2008, 01:03:20 PM »
http://www.amigafuture.de/kb.php?mode=article&k=2650 is the link to the stuff featured in Amiga Future issue #74.
selur
Re: Hi
« Reply #7 on: September 05, 2008, 12:12:15 AM »
Re: Hi
« Reply #8 on: September 20, 2008, 11:59:01 PM »
It's on the CD with the magazine. If I remember, I'll search on the CD Monday. (Can't do it tomorrow as me and my dad are gonna play Test Drive Unlimited and other games on the X360 tomorrow).
selur
Re: Hi
« Reply #9 on: September 21, 2008, 12:41:45 AM »
sure I'll wait.
