Author Topic: Amcaf installation problems  (Read 4107 times)
« on: June 20, 2009, 11:04:20 PM »
I've been trying to install Amcaf on my emulation setup and my real setup. I can execute the file called "ExecuteMeFirst!" fine, which I think sets up the labels or something for the installation process.
When I try to run the installation program it goes straight to a guru, has anyone had this before?
There are also 2 guides, one is called Amcaf.guide and the other is called Amosguide. The Amcaf guide identifies as a normal Amiga Guide file, where as the Amosguide file identifies as a CrunchMania file. I have tried changing the tooltypes and fixing the extension, but none of it works, I get guru'ed everytime I try to run it after I have attempted to fix it. The guru might just be my setup though, but the file still doesn't work. Maybe its not even meant to be a guide file, but just part of the AmcafGuide.
BTW, the AmcafHTML guide in the downloads section is doing the 0kb download thing again. I will let FOL know, but could someone try removing that file and THEN upping it again.
Re: Amcaf installation problems
« Reply #1 on: June 21, 2009, 07:01:06 AM »
I have managed to get amcaf installed manually, but I am sure it would be more useful and easier for begginers to be able to use the install file.
« Reply #2 on: June 21, 2009, 10:00:50 AM »
I don't think I ever did get the installer to work on AMCAF.  I always just did it manually.
« Reply #3 on: June 23, 2009, 03:20:26 AM »
Installers are unlikely to work on emulated machines, simply because many installers can't work with anything around the 4GB mark (or more). They see the memory size as being negative.
I don't recall using the installer, but then I was much happier installing things manually :)
