Author Topic: Amos Tome Extension [EXT]  (Read 11235 times)
asymetrix
  • Amos Documentation
« on: July 27, 2009, 07:36:38 PM »
Amos Tome Extension
by Aaron Fothergill
I have not had much time to check it :-(
Re: Amos Tome Extension [EXT]
« Reply #1 on: July 27, 2009, 08:27:16 PM »
You are a legend!  :)
« Reply #2 on: July 27, 2009, 11:47:39 PM »
That file is version 3, which will not work with the update that updates TOME and makes it work with AMOS Pro, but I have found the v3.1 update and have managed to get TOME working on AMOS Pro.
I have made it easier to install, so download the ZIP attached to this post and follow the instructions in 'ReadMe!.txt'.
I have a some books which have chapters on TOME, so I will probably scan those and upload them too at some point.
It's a great extension.  :)
\o/
« Reply #3 on: July 28, 2009, 01:39:13 AM »
Excellent!
« Reply #4 on: July 28, 2009, 05:21:12 AM »
Sorry about all the posts.
I have made a quick video to show what TOME can do and how it does it. I will make a better quality video showing more of the editor. Select fullscreen to see the video properly.
http://www.youtube.com/watch?v=8jbf-cSvPOg
« Last Edit: July 28, 2009, 05:25:19 AM by skate »
asymetrix
« Reply #5 on: July 28, 2009, 05:21:50 AM »
\o/
nice one !
I didnt even know there was an update. This is great.
« Reply #6 on: July 28, 2009, 05:27:39 AM »
Well, the other previous versions made by the original creator don't work with AMOS Pro, but some chap created this to update it and make it compatible. It is a very powerful and easy to use extension, I would place it second after AMCAF. :)
« Reply #7 on: August 01, 2009, 03:25:38 AM »
Hi all,
asymetrix, thanks for finding it. It has saved me from searching through all my Amiga floppy disks :)
skate, thanks for the update file and awesome video. I can't wait to get started with TOME. I just have to get some of my other projects done first.
asymetrix
« Reply #8 on: August 03, 2009, 05:07:12 AM »
Lonewolf10:
My pleasure, Im thankful Skate put the update and manual together.
How is your project going ?
Krakerman
« Reply #9 on: August 23, 2009, 03:49:50 AM »
I installed TOME just like you said in the readme, but when I click to run AMOSPro it says can't find extensions and I have those 2 files in the APSystem folder and the interpreter config in the right slots so I don't know why it's not working.
« Reply #10 on: August 23, 2009, 05:30:48 AM »
Have you ever managed to install any other extension before? My guess is that you have entered the filenames wrong or you changed the names of the files.
Krakerman
« Reply #11 on: August 23, 2009, 06:42:51 AM »
I have a whole bunch of extensions installed and I checked the filenames and they are all correct. I just re-checked and ran it again and it keeps giving me the following:
Cannot load extension-try using default interpreter config.
When I delete them out of the config file AMOSPro loads up ok
« Last Edit: August 23, 2009, 06:49:54 AM by Krakerman »
Krakerman
« Reply #12 on: August 23, 2009, 06:54:21 AM »
Maybe it's having problems with another extension in another slot, dunno
Krakerman
« Reply #13 on: August 23, 2009, 07:24:43 AM »
Yup it's conflicting with another extension. Which one not sure ... as I'll have to delete one by one and find out which one. I came to that conclusion as I installed it with a fresh AMOSPro and it works with no other extensions.
« Reply #14 on: August 23, 2009, 10:16:42 AM »
There are some tile functions in Turbo/Turbo Plus if you have either of these installed, you'll probably want to remove it.  AMCAF and TOME are a good combination and I can verify that EasyLife and the Ranger extension don't conflict with either of those two.  Currently I have all of those installed.  Also, AmosPro came with a few extensions so hardly anything conflicts with those.
