Author Topic: Amos Tome Extension [EXT]  (Read 11236 times)
Re: Amos Tome Extension [EXT]
« Reply #15 on: August 23, 2009, 05:36:10 PM »
There are some tile functions in Turbo/Turbo Plus if you have either of these installed, you'll probably want to remove it.  AMCAF and TOME are a good combination and I can verify that EasyLife and the Ranger extension don't conflict with either of those two.  Currently I have all of those installed.  Also, AmosPro came with a few extensions so hardly anything conflicts with those.
Why would the extension not show at all though? Does AP check the commands of all the extensions and removes any extensions with conflicting commands?
Krakerman, when you said, "but when I click to run AMOSPro it says can't find extensions", do you mean it comes up with an error/message?
When you say, "can't find extensions", do you mean all the extensions or just the two(TOME & Range) that you recently installed?
Krakerman
« Reply #16 on: August 27, 2009, 11:13:30 AM »
It says "Cannot load extension - use default interpreter config" well I tried removing the Turbo Plus extension and it still doesn't work.
Krakerman
« Reply #17 on: August 27, 2009, 02:21:59 PM »
UPDATE!!: Finally got it working seems my config file was either corrupt or something cuz I deleted it and started over and now all my extensions are working (Sheesh!!)  ;D
« Reply #18 on: August 31, 2009, 01:49:38 AM »
Lonewolf10:
My pleasure, Im thankful Skate put the update and manual together.
How is your project going ?
Slowly, I'm going to upload an updated Extension Command List to this thread shortly:
User Extensions Command List
« Reply #19 on: August 31, 2009, 02:00:32 AM »
No, AMOS Pro does not check for conflicting names when it loads. SamuraiCrow asked me a few months back to sort out a conflicting name problem with some Blitter commands in 2 extensions, but in the end I didn't need to do it.
If you load 2 extensions that have 2 identical commands, I have no idea which one AMOS would use when compiling or running your program. I would guess the first one in the list, example:
Extension in slot 2 with command Cls Turbo *might* be used before the Cls Turbo command in an extension in slot 5. (NB: There is no such command, afaik, it's purely an example)
This is why many extension commands are preceeded by either the authors initials, or an abbreviation of the extension name (e.g. Jd Pseudo Palette - a command by Joerg Dommermuth from his Jd Colour extension).
It's usually because of a problem with the last extension you added. You really need to run SnoopDOS to find out exactly which extension is causing the problem, and try to work out what the problem is from there.
« Last Edit: August 31, 2009, 02:03:50 AM by Lonewolf10 »
Krakerman
« Reply #20 on: August 31, 2009, 10:03:14 AM »
Like I said I just deleted the config file in the S directory and put the new one in there with exactly the same extensions I configured before and it works now. That's all that matters too me ... as long as it's working now
