Author Topic: Mouse Movement Recorder [EXE]  (Read 5205 times)
« on: November 21, 2009, 02:09:41 PM »
Hi folks,
Now that I am back I can upload the Mouse Movement Recorder (MMR) program I was talking about at the end of October in another thread. This is pretty much finished, unless anyone finds any bugs.
All the information you need is included in the archive, or within the program itself. For information on the file format, the program itself, or to switch from highres (640x250) to lowres (320x250) screens please go to the options screen. I have tried to make it internationally friendly, so you shouldn't require a UK keyboard setup (QWERTY) to get the menus to work.
Remember, you can create the data manually, or record mouse movements (which can be edited later).
Re: Mouse Movement Recorder [EXE]
« Reply #1 on: April 30, 2010, 08:16:17 PM »
I had a 3 month break from coding, and now I'm back. I have fixed the bugs I found in MMR when I was using it with something else I am working on, and added some improvements!
MMR - changes
 - Display glitch fixed when EDPOS near end of file and end of file deleted
 - Play position problem after editing (e.g. PLAYPOS=400, delete to 360, go to play mode) fixed
 - When deleting single data it no longer auto-exits
 - Mass delete option (eg. 400 - 1200) added
 - Record mode interface changed to use mouse, not keyboard.
 - Removed forced capitalisation of file names when saving
 - Added non-case sensitivity to file extensions on loading/saving
 - Fixed "no data" bug when there was data for saving/editing.
The new version of MMR (MMR_140410) can be found below (if you are logged in).
Edit, added 6th April 2011:
MMR now available on Aminet. Simply search for "ADBs" to find all my stuff.
« Last Edit: April 06, 2011, 07:06:09 PM by Lonewolf10 »
