Author Topic: PSPUAE 0.53 Released  (Read 31178 times)
0 Members and 6 Guests are viewing this topic.
« on: July 30, 2006, 07:15:34 PM »
Hi, we have released a new version (0.53), this is a small update,
v0.53
- Drive Speed option added (This helps alot with long loading games, it wont help with all)
« Last Edit: November 13, 2006, 08:06:16 PM by FOL »
ParaSitius
  • Swish
    • ParaSitius.com
Re: PSPUAE 0.53 Released
« Reply #1 on: July 30, 2006, 10:38:43 PM »
And it is very noticeable the speed difference that games load up now.
Another fine update.
« Reply #2 on: July 30, 2006, 11:13:58 PM »
Doesnt help on all games.
So no problems with the eboot?
metallklaus
« Reply #3 on: July 31, 2006, 09:12:41 AM »
Thanks, good work. Good Loadingtime now. I looking forward to a fullspeed amiga. :o
« Reply #4 on: July 31, 2006, 12:13:51 PM »
i dont test it yet..but
1 more time thanks to RIC  ;)
« Reply #5 on: July 31, 2006, 02:53:17 PM »
so.. after to 4-5 game test ..yes its faster Loading!
 :o
1 problem ..whit the save Options ,
 i cant save the new Options and after to reboot its still the older.
Hai
  • compute + compose
  • audio, video and stage artist
    • THE DUNGEON
« Reply #6 on: July 31, 2006, 03:52:44 PM »
This is important update! Thanks a ton!
A1200, Blizzard 68060 (clocked to 66mhz), Melody PRO audioboard, 16mb fast, 850mb HD, SCSI cd-rom
« Reply #7 on: July 31, 2006, 03:54:46 PM »
 :o
Ill look into it now.
« Reply #8 on: July 31, 2006, 04:01:28 PM »
 :o
Yes you are correct, but thats how its supposed to work.
PSPUAE has its own boot default (like WinUAE), then you change settings and save them as a config file. now if close program, then restart, it will load its own defaults. Once you load your config file, then the options will load to yours.
Hope that makes sense.
« Reply #9 on: July 31, 2006, 04:54:52 PM »
Will add this comment to next readme,
"Cause no one ever reads anything (DRIVE SPEED OPTION DOESNT HELP WITH ALL ADF`S)"
I`ve been seeing, there is no difference after trying 1 adf, come on people, try more than 1. Your DVD player doesnt read 1 disc, do you try another YES.
« Reply #10 on: July 31, 2006, 08:16:16 PM »
friend FOL .. its bug im sure for this coz.. the 0.52 has not this problem
i mean for Save Options.
(we can not we make new settings ,as default settings)
i hope RIC coming  to see this post and fix at soon.
« Last Edit: July 31, 2006, 08:21:28 PM by Anemos »
« Reply #11 on: July 31, 2006, 09:01:27 PM »
Ill look soon, busy working on something else atm
dt311077
« Reply #12 on: July 31, 2006, 09:32:03 PM »
Is tiff eboot loader supported in this version?
If not have you any plans on making version?
« Reply #13 on: July 31, 2006, 09:43:28 PM »
Nope, TIFF exploit has and never will be supported (well to my knowledge Ric has no plans to make a version, but I could be wrong). There is an older version for GTA ELoader though in the downloads section.
Has anyone tried this verion on GTA ELoader?
Exoskeletor
  • PSPUAE Site Staff
« Reply #14 on: July 31, 2006, 10:25:39 PM »
great release
Live And Let Die
Amiga Will Never Die PC User
