Author Topic: ADB Extension 24  (Read 9632 times)
ADB Extension 24
« on: August 20, 2010, 10:21:09 AM »
I have thought of a few commands which I may add to my own extension shortly (especially if I can't get the copper effects to work as I want to in my Extension Examiner program):
   - Reserve As Screen BANK,WIDTH,HEIGHT,COLOURS,[Hires|Lowres|Laced]  (primarily for copper screens)
   - Screen Bank X   (Sets currently active Screen Bank)
   - SB Print At(X,Y),TEXT$   (Same as Print command, but uses current Screen Bank)
   - Reserve As Zone Bank SCREEN,MAX_ZONES   (creates a Zone Bank)
   - X=Mouse Zone(X)   (returns -1 if mouse within Zone X, as defined in the Zone Bank)
Any comments or suggestion for more commands welcome.
Re: ADB Extension 24
« Reply #1 on: August 22, 2010, 08:17:47 PM »
Hi Lonewolf10,
I was wondering if you would be interested in making an AGA-only extension that would make a 64-pixel wide sprite overlap the side border of an underscanned screen (using the BorderSprite bit) so that there could be two screens side-by-side on the display.  The sprite would be the sidebar, and the rest would be the main part of the screen.  The goal of such an arrangement would be to make them scroll independently of one-another (although the sprite could only scroll vertically) using the screen offset command or an equivalent.
I'm willing to help out as long as I have time.  Maybe I could make some of this code a shared library that would be called by the extension so it could be used by other programming languages.  I've found out that AmigaE makes buggy shared libraries and that the module format of AmigaE isn't 100% debugged either.  I'll probably be writing it in C as a result of that.
Let me know what you think!
KevG
« Reply #2 on: August 22, 2010, 09:51:56 PM »
I would love to see a custom made dual playfield display made up off 4 colours and 16 colours instead of eight and eight. I've tried all sorts of stuff like swapping planes around but I gave up in the end.
Keep up the good work. There's not many of us AMOS devs around so its nice to know that there are people around like you who are putting the time and effort in to make AMOS better.
Cheers, Kev G.
« Reply #3 on: August 23, 2010, 03:16:51 AM »
Doing more than 8 colors in a playfield requires the AGA chipset.
KevG
« Reply #4 on: August 23, 2010, 01:21:16 PM »
Thats what I thought until Brian The Lion came along (ECS version). This game uses 4 colours in the
background and 16 in the front playfield. I think they managed to do it by swapping planes around so that the transparent plane was set one plane further back in the order. I've tried it myself but haven't had much success  :-[
« Reply #5 on: August 24, 2010, 03:52:25 PM »
@KevG
That is a hack.  I don't know if it will even work on future Amigas like the MiniMig.  If the registers were mapped the same way as the AGA chipset handles playfields, then maybe it will work on the NatAmi.
« Reply #6 on: August 25, 2010, 04:31:34 PM »
You couldn't of thought of something simpler?!  I have no experience with the AGA chipset and I'm not sure if my RKRM's cover it. I haven't tried writing anything that calls a library function yet either, so this would take quite a bit of research before attempting to do it.
Quote from: KevG
I do know that it is possible to change the number of bitplanes on each playfield in dual playfield mode (e.g. 2 colours for one and 32 for the other), however I have not tried doing this myself yet and, as SamuraiCrow has already said, it may require sort of hack.
« Reply #7 on: August 25, 2010, 07:44:13 PM »
I may just use the FD to extension converter if I can figure out how to make the library work.  I may be getting in over my head as well.  The RKRMs only cover ECS but there is an AGA Guide file in AmigaGuide format that will help.
-edit-
I've got a better research project for you that will work on OCS/ECS.  I've been looking to make a replacement for the MrgCop() subroutine in Graphics.library.  It is slow because it only deals with one Copper instruction at a time.  Could you write one that batches instructions together?  You may need to look a little deeper into the View and ViewPort structures in the RKRMs since they will probably require some modifications as well.
« Last Edit: August 26, 2010, 08:23:11 PM by SamuraiCrow »
« Reply #8 on: August 29, 2010, 12:05:31 AM »
-edit-
Good luck with the FD thing. I think I tried that long ago and came unstuck, but I'm sure you'll have better luck with it.
Improving MrgCop() does sound intriguing. Batching instructions might be a little tricky, but I'll have take a look at the View and Viewport structures and see whether I think it can be done.
« Reply #9 on: August 30, 2010, 12:23:58 AM »
Today I checked in the official Amiga HRM's (Hardware Reference Manuals) - I have 2 sets, one from 1985 and one from 1989. Both state the same thing, each playfield can only use between 0 and 3 bitplanes, so you can only have a maximum of 8 colours per playfield (unless you do some tricks using the copper/copperlist).
Colour 0 is used as transparent for playfield 1 and Colour 8 is used as transparent for playfield 2.
« Reply #10 on: August 31, 2010, 08:00:06 PM »
This may be of some help. Whilst searching for help on how to display sprites I came across this collection of web-based Amiga RKRM's, which includes FD files here:
http://amigadev.elowar.com/read/ADCD_2.1/Includes_and_Autodocs_2._guide/node0000.html
I hope that helps.
« Reply #11 on: September 01, 2010, 02:18:52 PM »
@Lonewolf10
I have the FD files for the OS already.  I would be making a new FD file for my library.  BTW, the files you found on elowar's server are just copies of the ones on the Amiga Developer CD 2.1 which I already have.
