Author Topic: Extension Examiner [EXE]  (Read 3837 times)
« on: September 08, 2010, 09:48:13 PM »
Hi folks,
I have come to a point where I am willing to release what I have as a Beta version. The reason for this release is that because this program can display alot of text it eats away at the buffer very quickly, and to solve this problem (e.g. write my own Print command) will take another month or two.
The only other problem with this is that for some reaon it crashes when you quit. I have used the System command before to exit from my programs without any hassle, so I am clueless as to why this is happening :(
Anyway, attached is the beta version of the Extension Examiner. I suggest you use the export option after loading in the extension of your choice (AMOSpro.lib is an interesting one to examine with commands option, however it fails the info option).
Re: Extension Examiner [EXE]
« Reply #1 on: November 16, 2010, 09:31:50 PM »
Hi folks,
Finally got it finished ;D
Here is the final version of my extension examiner program. It even works with AMOSPro.Lib, whereas the Beta version fell over almost straight away!
I have included an amigaguide file with some basic info on syntax translation, including examples. It also has info on how to use my program, though it should all be straight forward to use :)
Edit, added 6th April 2011:
Extension Examiner - Final, now available on Aminet. Search for "ADBs" to find all my stuff.
« Last Edit: April 06, 2011, 07:04:34 PM by Lonewolf10 »
