Author Topic: AMOS Pro libraries updates  (Read 4091 times)
rockersuke
« on: February 25, 2011, 07:08:23 PM »
Now you can laugh at my blatant ignorance, but I was so out of touch with Amiga things in the late nineties that I didn't know until yesterday that there were some AMOS Pro libraries updates.  :D
I was installing an AMOS program when I noticed It used an amos.library file different from the one in my AMOS Pro 2.00 setup. It was a 2.30 version which, now I see  :D, is also available as a download here together with another AMOSPro.lib file.
Should I replace my 2.00 amos library and AMOSPro.lib with these ones? Are they official? Are there any docs with info about what they fix/enhance?
You're never too late to learn something new!  ;D
Re: AMOS Pro libraries updates
« Reply #1 on: February 26, 2011, 09:16:41 PM »
I know that Pietro Ghizzoni (a member of the AMOS-list Yahoo group from about 10 years ago) did do some updates to some of the AMOS Pro files to fix a few things.
As long as you are using AMOS Pro, then yes I suggest using the newest files - but keep the old files somewhere safe just incase :)
rockersuke
« Reply #2 on: February 27, 2011, 01:01:18 AM »
OooK! It's replacing time, then! I've taken a peek into Pietro's meessages at the Yahoo list around 2000, and I'll have also a go with those libs patches I hadn't noticed. Thanks!
« Reply #3 on: April 06, 2011, 06:48:18 PM »
No problem :)
Did you find them and get them installed?
