Author Topic: Saving game progress  (Read 10773 times)
obmij77
« on: March 03, 2011, 08:57:46 PM »
Having trouble understanding saving game progress. Do i use the savestates? When I do so with storm master and go into save states if i press on the title it crashes the program, if i press on #1 it doesnt seem to save....am i doing the right thing?
Thanks
Re: Saving game progress
« Reply #1 on: March 04, 2011, 02:44:16 PM »
Thanks
Depends which version your running, as 0.80 has a nasty bug that crashes when saving a state, unless you load a savestate first.
Very wierd bug.
Try 0.72, thats fine with saving.
Saving as state #1, can cause a problem as this is the default boot config.
So if there is a problem with your config, then pspuae see's #1 config on boot and uses it.
delete #1 from state dir and config dir. Then restart PSPUAE.
See if that helps.
« Last Edit: March 04, 2011, 02:48:57 PM by FOL »
obmij77
« Reply #2 on: March 04, 2011, 07:16:07 PM »
Using 0.72, will try again using save states, but wondered if using adf disks meant using an adf save disk instead of save states. Infact i presumed save states was for pre-loading disk/pspuae settings per game.
Will try again...
Thanks
« Reply #3 on: March 04, 2011, 07:25:45 PM »
both methods can be used to save games - sometimes the ADF savedisk route is quicker. Save-States store the entire amiga memory and registers, so can be quite large sometimes.
obmij77
« Reply #4 on: March 04, 2011, 10:54:35 PM »
Must have changed config/uae cos now working after re-install and save state using named save state. Interested in add saves though, how do they work?
obmij77
« Reply #5 on: March 04, 2011, 10:56:41 PM »
Thanks
Meant ADF....
« Reply #6 on: March 04, 2011, 11:05:28 PM »
Thanks
Meant ADF....
He means like we all did back in the day.
Games with save disks, :).
Mr. Bungle
« Reply #7 on: January 13, 2012, 03:12:16 PM »
Hi there,
I cannot save or load states on 0.80. I've tried to install 0.72 with no luck (corrupted data message). Can anybody help please?
Thanks
« Last Edit: January 14, 2012, 10:43:23 AM by Mr. Bungle »
« Reply #8 on: January 15, 2012, 10:44:35 PM »
Hi there,
Thanks
Need more info.
What PSP FW are you using,
How are you installing?
etc etc.
Mr. Bungle
« Reply #9 on: January 16, 2012, 01:54:08 PM »
First of all congratulations for your outstading job. Amiga is my all time favourite system and I am delighted to run it on PSP 1004. FW is 6.31. I've only managed to install PSPUAE 0.80 (SIGNED) but have this problem with save and load states! It blocks when I am trying to save and turns off the PSP.
dan
  • Emerald Mine Addict
« Reply #10 on: January 16, 2012, 04:23:29 PM »
hmm... could be one of these:
- wrong folder structure, states should be in a subfolder "STATE", config files go in "CONFIGS"
- missing or improperly named kick.rom files. Many of the states from this site require kick.rom 3.0 or kick.rom 1.3, not sure wether others are used too. They should be named kick13.rom etc, and they have to be in subfolder "KICKS".
Hope this helps.
Mr. Bungle
« Reply #11 on: January 16, 2012, 04:45:02 PM »
I use the subfolders correctly and kick13.rom. I can play the games fine and the only problem is the save state...
« Reply #12 on: January 16, 2012, 05:06:02 PM »
i found the 0.80 signed beta very buggy, so it could just be that.
I have CFW PSP, so I always favour an un-signed version if i'm honest.
I assume you have no problem with v0.72, which was the last stable release. I'm afraid there are no guarantees with beta versions!
Mr. Bungle
« Reply #13 on: January 16, 2012, 06:06:54 PM »
I guess I just have to wait in order to save and load states in a upcoming signed version. Thanks for your kind help.
« Reply #14 on: January 16, 2012, 06:30:56 PM »
Ah, now I know what your on about.
Horace I think he is talking about the savestate memory bug, that would hang the psp.
Thats been fixed since beta 10? if I recall.
As I posted in another thread, been busy at the moment with work stuff.
