Author Topic: PSPUAE: PSPUAE V0.80 BETA 15 (UPDATE 13-5-11)  (Read 16919 times)
RedBaron
Re: PSPUAE V0.80 BETA 15 (UPDATE 13-5-11)
« Reply #15 on: June 20, 2011, 07:58:18 AM »
Hi
I have noticed when playing Beta 13 and 15 that if you have the turbo disk on it doesn't load the game
Beta 15 is noticeable faster than Beta 13, I have found that if you use 2.04 kickstart rom instead off 1.3 kickstart rom with frame skip 10 when playing Gods I am getting 35fps  ;D ;D ;D
Also what do the indicators on the top right supposes to represent I have been trying to find out but I have had any successes
« Last Edit: June 20, 2011, 09:47:29 PM by RedBaron »
« Reply #16 on: July 05, 2011, 11:04:15 PM »
Im still working on this, but at a slower pace at the moment.
I have a few key things to sort out, before I can get back to it more.
EDIT:-Im hoping to have stuff sorted this weekend (fingers crossed), so I can finally get round to sorting site out and working more on PSPUAE.
« Last Edit: July 08, 2011, 09:00:04 AM by FOL »
« Reply #17 on: July 08, 2011, 09:01:42 AM »
Bit of a late reply, but they are the system indicaters.
Power, CPU usage, Frameskip, drives, etc etc.
« Reply #18 on: July 13, 2011, 11:00:42 PM »
There appears to be a new pspsdk release.
Fingers crossed it fixes the issues it added to updated source.
Also almost finished tidying my system, so should be able to play with it soon.
dan
  • Emerald Mine Addict
« Reply #19 on: July 14, 2011, 11:54:50 AM »
heh heh ... this sounds good.
« Reply #20 on: July 15, 2011, 08:25:02 AM »
Well lets hope, cause the new toolchain adds aload of stupid bugs.
Theres nothing wrong with code, but it makes it crash when doing simple things.
Old toolchain and its perfect, but you loose all the benefits of new toolchain.
« Reply #21 on: July 16, 2011, 11:37:26 PM »
Same issue.
So Im looking more in depth at whats changed.
