Author Topic: Rotating a cube...  (Read 3378 times)
Rotating a cube...
« on: August 05, 2011, 06:24:32 PM »
Hi
I have been studying up on trigonometry and displacement vectors in order to try to rotate a cube in my assembler demo I am working on. However, before writing the ASM code I was trying to use AMOS to make sure that the maths was all correct.
The good news is that the maths seems to be correct, but when AMOS reaches the line COORDS(S,1)=NEW_X it seems to crash (actually, it seems to go into an infinite loop and then it crashes about 10 seconds later).
I thought it might have been a problem storing negative numbers, but a quick 3 line program proved that not to be the case.
Any ideas anyone?
ROTATE_CUBE:
   Dim COORDS(8,3)
' Rotating angles...
   A1=90 : A2=90 : A3=90
' Calculate constants for new angle
   Print "Calculating constants for new angle..."
   Print : Print "C1,C2,C3 and S1,S2,S3"
   C1=Cos(A1) : C2=Cos(A2) : C3=Cos(A3)
   S1=Sin(A1) : S2=Sin(A2) : S3=Sin(A3)
   Print : Print "XX,XY,XZ"
   XX=C2*C1
   XY=C2*S1
   XZ=S2
   Print : Print "YX,";
   YX1=C3*S1
   YX2=S3*S2*C1
   YX=YX1+YX2
   Print "YY,";
   YY1=-C3*C1
   YY2=S3*S2*S1
   YY=YY1+YY2
   Print "YZ"
   YZ=-S3*C2
   Print : Print "ZX,";
   ZX1=S3*S1
   ZX2=C3*S2*C1 : Rem ;s2*c1+c3*s1
   ZX=ZX1-ZX2
   Print "ZY,";
   ZY1=-S3*C1
   ZY2=C3*S2*S1 : Rem ;c3*c1-s2*s1
   ZY=ZY1-ZY2
   Print "ZZ"
   ZZ=C3*C2
' Calculate new coordinates using new angle
   For S=1 To 8
      Read X,Y,Z
      Print : Print "S=";S;" - X,";
      X1=XX*X
      X2=XY*Y
      X3=XZ*Z
      NEW_X=X1+X2+X3
      Print "Y,";
      Y1=YX*X
      Y2=YY*Y
      Y3=YZ*Z
      NEW_Y=Y1+Y2+Y3
      Print "Z"
      Z1=ZX*X
      Z2=ZY*Y
      Z3=ZZ*Z
      NEW_Z=Z1+Z2+Z3
   Print "S=";S
   Print "NEW_X=";NEW_X
   Print "NEW_Y=";NEW_Y
   Print "NEW_Z=";NEW_Z
   End
      Print : Print "Storing new coords..."
      COORDS(S,1)=NEW_X
      COORDS(S,2)=NEW_Y
      COORDS(S,3)=NEW_Z
   Next S
   Data -10,-10,10 : Rem top-left (front)
   Data 10,-10,10 : Rem top-right (front)
   Data -10,10,10 : Rem bottom-left (front)
   Data 10,10,10 : Rem bottom-right (front)
   Data -10,-10,-10 : Rem top-left (back)
   Data 10,-10,-10 : Rem top-right (back)
   Data -10,10,-10 : Rem bottom-left (back)
   Data 10,10,-10 : Rem bottom-right (back)
« Last Edit: August 05, 2011, 06:26:05 PM by Lonewolf10 »
Re: Rotating a cube...
« Reply #1 on: August 05, 2011, 06:31:35 PM »
Arggghhhh!  >:(
I have been programming in assembler for so long (last 9 months) that I forgot one of the bugs in AMOS - anything after a Data statement causes AMOS to crash :(
Edit:
Errr... it seems something is wrong with the maths.
A=90, B=0,C=0 coords returned are:
1 = -10,-10
2 = 10,-10
3 = 10,-10
4 = 10,10
In short, points 2 (top-right @ front) and 3 (bottom-left @ front) have swapped positions!! I'm trying to rotate point 1 to 2, 2 to 3 etc.
A=90, B=90, C=90 coords returned are:
1 = 10,-10,-10
2 = 10,-10,10
3 = 10,10,-10
4 = 10,10,10
This isn't right, is it?
« Last Edit: August 05, 2011, 07:20:37 PM by Lonewolf10 »
« Reply #2 on: August 07, 2011, 11:57:57 AM »
Ummmm... Have you checked the AMCAF demo source?  I'm pretty sure it had a few rotating cubes in it.
« Reply #3 on: August 15, 2011, 12:57:38 PM »
The only AMCAF demo's I have are:
Fire.AMOS
ScreenTrans.AMOS
Neither have rotating cubes, but they do have cool effects though :)
