Author Topic: Minor page display issue  (Read 3938 times)
« on: November 08, 2011, 12:25:18 AM »
Noticed a minor problem with the footer text. Attached image shows what I am seeing on any page I visit.
Using Firefox 7.0.1
Re: Minor page display issue
« Reply #1 on: November 08, 2011, 03:06:42 PM »
looks like a missing < br > in the index template.
I will look into it!
« Reply #2 on: November 08, 2011, 09:10:30 PM »
Dont think
 would case that.
« Reply #3 on: November 09, 2011, 10:44:27 PM »
managed to remove it completely without killing the copyright notice. Should look much neater now.
« Reply #4 on: November 10, 2011, 08:02:04 AM »
Ah, you need to show the SMF copyright / link, but you can loose the version, thats fine.
Basically the same way as TP, you have now at bottom.
« Reply #5 on: November 12, 2011, 05:40:00 PM »
Horace,
Found a colour error. Its on all themes apart from red.
Go to "users online", red banding, :).
Also, really need SMF Copyright in footer else we will be in trouble.
