Author Topic: Modifying Creator/Owner posts  (Read 3300 times)
« on: November 21, 2011, 12:11:50 AM »
Couple on questions on this.
1.) I have seen a modify button available when I post a new topic, then after a period of time it is no longer available, What is the time out on modifying a new post.
2.) Is it possible to give the Creator/Owner of a post, permission to modify their post at any time. Might be a good reason for not allowing it, excuse my ignorance.
On the subject of my ignorance, there is a wee green box under A600, what does it represent.
Can't search the site for answers, getting this message.
"Due to high stress on the server, the search function has been automatically and temporarily disabled. Please try again in a short while."
Your probably aware there is no formatting icons in the post form, thought I'd mention it anyway.
Re: Modifying Creator/Owner posts
« Reply #1 on: November 21, 2011, 12:25:43 AM »
Try it now, :).
Search should also now work.
Green square, just means your green, :).
Nah, its just a rank, as you post more it will increase. Admins, mods, GM's have different coloured squares.
« Last Edit: November 21, 2011, 12:29:13 AM by FOL »
« Reply #2 on: November 21, 2011, 12:37:18 AM »
Thanks FOL
This will be great for the AMOS manuals. I'll only need to update the top post with any status changes. I'll cleanup a couple of other posts so as not to confuse visitors. I'll do this when I upload the AMOS creator manual. It was my mum's birthday at the weekend so I didn't get the rest of the manual finished, it'll be little bit delayed.
« Last Edit: November 21, 2011, 09:45:22 AM by MadAngus »
