Author Topic: Timer  (Read 2265 times)
BooBoo
  • Amiga Guru
Timer
« on: December 29, 2011, 07:34:18 PM »
Any ideas how I could have an accurate timer not affected by my loop, AMCAF has time commands indluding seconds but realy id like milliseconds
On a thread on EAB Samurai_Crow mentions using the timer.device with Dev commands
Any ideas?
Re: Timer
« Reply #1 on: January 04, 2012, 06:55:31 PM »
the Timer command of AMOS counts 1/50th of second, and you can reset it to zero at any point with TIMER=0 .... is that any good?
This shouldnt be affected by the loop and i use it myself to ensure that each game loop takes at least 1/50th of a second to occur. (i.e. therefore remaining unaffected by JIT settings etc)
BooBoo
  • Amiga Guru
Re: Timer
« Reply #2 on: January 04, 2012, 09:00:55 PM »
Thanks for you reply I had a bit on an idea dividing a second by 60
Re: Timer
« Reply #3 on: February 14, 2012, 08:53:54 PM »
Don't forget to check whether the system it's being run on is PAL or NTSC - unless you just plan to use it on an NTSC system. For PAL systems a second is 50 VBLs.
