Author Topic: "better" MED commands  (Read 3473 times)
« on: January 24, 2012, 11:03:59 AM »
hello all
I was just wondering, as i thought i had seen it somewhere (although perhaps my mind is playing trick on me)  whether any extensions had "better" OctaMED playback commands than those built-in to AMOS Pro?
I've noticed there is no way to fade OctaMED modules, so I may have to convert my files to Protracker and use AMCAFs excellent PT commands. The trouble is, I use a number of 'MED specifiy things, like 128 line block lengths, and I would prefer to stick to using my 'MED versions without having to butcher them!
Re: "better" MED commands
« Reply #1 on: January 24, 2012, 12:24:32 PM »
I guess musiCRAFT does not have what you need?
« Reply #2 on: January 24, 2012, 02:23:01 PM »
i dont think i have it installed, but it seems unlikely the ST Volume command will affect a playing MED (nothing else has)
