Author Topic: FS-UAE 0.9.8 released  (Read 11112 times)
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
« on: February 18, 2012, 09:30:58 AM »
* Support for SmartJoyPlus/TigerGame PS/PS2 adapter (courtesy of smuj)
* Can specify less accurate emulation modes (for slower machines).
* Detect when xrandr lies about refresh rates (nVIDIA twinview).
* Fixed bug when using left crtl/alt/shift simultaneously with emulated keyboard.
* New suggested extension for configuration files (*.fs-uae)
* New default config file location: (My) Documents/FS-UAE/Configurations/Default.fs-uae
* New default dir for kickstarts: (My) Documents/FS-UAE/Kickstarts
* New default dir for save states: (My) Documents/FS-UAE/Save States
* Path expansion for paths beginning with $HOME/ or ~/
* Fixed crash when custom limits (autoscaling) rect was outside video size.
* New model configuration: "A1200/020" (can use Zorro III memory).
* New configuration value: zorro_iii_memory.
* Audio buffering tweaks.
* Clamp FSAA value to [0, 4] range.
* Virtual file system update (ported code from WinUAE).
* Mac OS X build is universal x86_64 + i386.
Binaries and source at http://fengestad.no/fs-uae/
Re: FS-UAE 0.9.8 released
« Reply #1 on: February 18, 2012, 02:41:13 PM »
fs, since you released the 0.9.8 beta, i have been unable to rename the application file?
I usually rename it with the version number, to prevent myself accidentally loading an older version. However, when i do so, the application no longer works, with this logo showing;
trying to run this, says the file may be "damaged or incomplete" ... although i can re-name it back, and it works fine.
Also, since the 0.9.8 beta, i have a problem of full-screen mode opening with the OSX window-bar being visible at the top. This did not occur in the 0.9.7 version iirc. (i notice this was also reported on EAB)
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
« Reply #2 on: February 18, 2012, 04:44:25 PM »
Yes, I have accidentally corrupted the Info.plist file (The reason it works when it's not renamed is possibly that Mac OS launches an older app bunble on your system instead). Version 0.9.8u2 for Mac OS X is posted at http://fengestad.no/fs-uae/
« Last Edit: February 18, 2012, 06:12:57 PM by FrodeSolheim »
« Reply #3 on: February 18, 2012, 05:43:00 PM »
thanks for the quick fix fs.
Curiously, I should have reported it during the beta phase, but I assumed it wouldnt be there in the release version, so i ignored it!
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
« Reply #4 on: February 18, 2012, 05:56:07 PM »
Yes, I broke it while making "support" for beta-release version numbers ;-)
On another topic, I will probably soon need beta testers for netplay support...
Forgetful Jones
  • Amiga 1200
« Reply #5 on: February 19, 2012, 10:52:34 PM »
Hi there!
I think it's a wonderful idea to have multi-platform netplay for classic Amiga games on emulators.
I'm also very fond of the gamepad gui approach.
I wonder if it is possible to compile this for PPC, as we still own and use a Power Mac G5 (2.7 GHz) running Mac OS X 10.5.
(I also have an Intel-based notebook, but it would be way cool to be able to play versus my brother living in the same house.)
It would also rock to have Raspberry Pi support.
I read somewhere that someone did an assembly-based Amiga emulation core for ARM processors.
Originally developed for iPhone? but never released. So we might have a reasonable fast Amiga emulator on the raspberries soon.
Then we would "just" need to implement compatible netplay code. Oh sorry, I just got carried away. ;)
Anyway, great work Frode Solheim!
« Last Edit: February 19, 2012, 10:59:05 PM by Forgetful Jones »
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
« Reply #6 on: February 19, 2012, 11:04:49 PM »
Hi there!
It is probably compilable on PPC, but I don't have a PPC Mac, so I won't compile/test for that architecture. Also, I don't have 10.5, so I only provide binaries for 10.6+
I read somewhere that someone did an assembler-based Amiga emulation core for ARM processors.
The Raspberry PI will probably not be fast enough to run FS-UAE (as you indicated), so you would need a optimized and less accurate emulation. Netplay is dependent on the emulation being identical on all connected clients, so this would be difficult to achieve (i.e. if one client uses cycle-exact emulation, everyone must) :-/ Even a tiny difference in the accuracy of the emulation will make games get out of sync.
Thank you :) -And remember, it's still "beta" (well, I haven't stated this anywhere, but I consider it beta until 1.0 ;-)), so just report problems if you find any.
« Last Edit: February 19, 2012, 11:21:03 PM by FrodeSolheim »
« Reply #7 on: February 22, 2012, 11:40:45 PM »
Version 0.9.9beta1 released
* Scanline effect support (see example.conf).
* Added an application icon.
* Associate .fs-uae files with FS-UAE on Mac OS X.
* Can override controller configurations by placing configs files in new FS-UAE/Controllers directory (+ option to configure this directory).
* New configuration option: audio/floppy_drive_volume
* New configuration option: paths/base_dir
* Ported updated caps code from WinUAE.
* New frame limiting logic in libfsemu.
* Use rawinput in Windows for keyboard support.
* Use some keyboard scancodes on other platforms to improve key mapping.
http://fengestad.no/fs-uae/files/fs-uae-0.9.9beta1-windows.zip
http://fengestad.no/fs-uae/files/fs-uae-0.9.9beta1-macosx.tar.gz
0.9.9 Beta  now here also :)
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
FrodeSolheim
  • fs-uae Dev
    • FS-UAE Homepage
« Reply #9 on: February 23, 2012, 10:20:25 PM »
Version 0.9.9beta2
combined changes since 0.9.8:
* Support hard disk files in RDB format (same config option as regular HDF files - RDB format is automatically recognized).
* Auto-grab input on mouse click.
* Click middle-mouse button to release input grab.
* Grabbing input on startup is optional (see example.conf).
* Keys are now "positionally" mapped (as far as possible) from host keyboard to amiga keys (some exceptions because of physically different layout: home = lparen, page up = rparen, delete = del, end = help, insert is mapped to the amiga key to the left of backspace, and page down to right amiga key in case the host keyboard has no right windows/apple/menu key).
* Make caps lock a proper toggle button.
* Support bsdsockets on Mac OS X / Linux (not Windows yet).
* NTSC mode added (see example.conf) -was really added in 0.9.8, but omitted from changelog.
http://fengestad.no/fs-uae/files/fs-uae-0.9.9beta2-windows.zip
http://fengestad.no/fs-uae/files/fs-uae-0.9.9beta2-macosx.tar.gz
http://fengestad.no/fs-uae/files/fs-uae_0.9.9beta2-0_i386.deb
http://fengestad.no/fs-uae/files/fs-uae_0.9.9beta2-0_amd64.deb
http://fengestad.no/fs-uae/files/fs-uae-0.9.9beta2.tar.gz
« Reply #10 on: February 24, 2012, 04:54:56 PM »
Not sure if this helps.
People who dont have a menu key or right win key, but however have a Function (F) key.
They can use Ctrl - left win - F + Print Screen.
Apparently F+Print Screen = right win key.
EDIT:-Sorry ment Print Screen, not Scroll Lock.
« Last Edit: February 24, 2012, 10:46:03 PM by FOL »
