Author Topic: FS-UAE 0.9.12 Released  (Read 15437 times)
Re: FS-UAE 0.9.12 Released
« Reply #15 on: March 17, 2012, 01:45:03 PM »
A fade would look nice :) I guess th other option is to "cut" the edge off, and then make any selected/highlighted text scroll?
Glad to here there are more HD/Netplay fixes on the way!
FrodeSolheim
  • PSPUAE Moderator
    • FS-UAE Homepage
« Reply #16 on: March 17, 2012, 02:11:11 PM »
Yes, but cutting/scrolling should be combined with fading to get the nicest effect.
I just put up beta4: http://fengestad.no/wp/fs-uae/download-beta
* New options: window_width, window_height, window_resizable.
* File system mounting is compatible with net play.
* Show title / subtitle strings in window title.
* Clear keyboard modifier state when window is activated / receives focus.
EDIT: I believe zip and folder mounting should now be able to work perfectly with net play. HDFs will probably not work without desyncs because threading is used to implement HDF support.
« Last Edit: March 17, 2012, 03:29:24 PM by FrodeSolheim »
