Author Topic: Post attachement downloads  (Read 3367 times)
« on: March 11, 2012, 01:42:23 AM »
When I click to download an attached file within a post, specifically with a *.pdf extension, it does not return [filename].pdf, instead I get [filename] alone. Does not happen with *.zip extension.
For example, when I click the "Legend Adventurers Handbook.pdf" from the "Legend Adventurer's Handbook" post, "Legend" is returned in the Firefox download box, no extension.
Is it just me?
Firefox 10.0.2, had the same issue with FF7
Re: Post attachement downloads
« Reply #1 on: March 11, 2012, 12:57:15 PM »
Is it just me?
Proberly from when we migrated DB to new version of software.
We will have to fix them as reported.
Quick fix = mod post, download file, save as filename.pdf.
Then untick current attachment and browse for file you just downloaded.
Then save, this will delete old entry and upload new fixed file.
Check the post in question.
« Reply #2 on: March 11, 2012, 01:01:50 PM »
Will do that in future. :)
