Author Topic: FS-UAE General Feedback, Requests and Suggestions  (Read 5313 times)
« on: April 04, 2012, 05:54:17 PM »
FrodeSolheim posted this over on EAB, so i am hoping he wont mind the same thing being here.....
This thread can be used to post general feedback and suggestions. Feedback and comments specific to the latest stable (1.0.x) or development (1.1.x) version can be posted in their respective threads.
For more complex issues and bug reports, or when you think your post will likely generate several follow-up posts, please consider creating a separate thread as it will be a bit easier to follow the discussion then.
Don't worry too much about where to post though, the most important thing is to just post somewhere if you have something on your mind
The latest stable version of FS-UAE is 1.0.2: http://fengestad.no/wp/fs-uae/download
The latest development version of FS-UAE is 1.1.1 http://fengestad.no/wp/fs-uae/download-beta
Information about new versions (stable and development) will be posted to the respective threads.
Re: FS-UAE General Feedback, Requests and Suggestions
« Reply #1 on: April 04, 2012, 06:01:16 PM »
Suggestions:
- Checks of HD files/folders between online players
- The possibility to "sync" HDs,  including ZIP, HDF and Folder contents between online players.
---- Folder contents and HDF/ZIP file syncs >5 meg to come with a "warning" before syncing.
---- If sync. is rejected by a player then they are disconnected from the game
- The discussed [Player 1] [Player 2] controller setups with a config. Once FS-UAE is launched, a user should be able to see which player he is set up as. Onlien Users should be able to 'swap' to being another player if required.
- Online Server script to 'cleanly' close once disconnected
- Online Server script to restart automatically once connections are lost etc.
i think that's all for now!
« Reply #2 on: April 07, 2012, 06:36:10 PM »
new thought:
when setting controller mode, e.g. none, mouse, joystick, cd32.... perhaps "custom" could be an option, so that the manually adjusted custom controls only "kick in" when the custom mode is selected.
This would allow online players who dont want the custom mapping (i.e. want to use original joystick/keyboard settings, like a real amiga) can "un-select" the cusotm layours of a config, while allowing the other player to continue using them.
