Author Topic: FS-UAE 1.2 Stable Series  (Read 5239 times)
FrodeSolheim
  • PSPUAE Moderator
    • FS-UAE Homepage
« on: April 30, 2012, 08:33:48 PM »
I am pleased to announce version 1.2.0 of FS-UAE, the multi-platform Amiga emulator for Windows, Linux and Mac OS X! FS-UAE 1.2 can be downloaded here.
Notable changes since version 1.0 include:
  • Great rendering performance improvements, especially on slower hardware.
  • OpenGL renderer compatible with older GPUs (only requires OpenGL 1.1 now).
  • Input devices and options can be changed in the menu while running FS-UAE.
  • UAEGFX card (“Picasso 96″) is implemented.
  • Added A4000/040 model, running in fastest possible mode.
  • Support for mounting CD images for all Amiga models (built-in CDFS and CD image switcher in menu).
  • Fullscreen/window mode switching with Alt+Enter, better fullscreen handling.
  • Better net play support (show dialog while connecting, will retry  connecting until successful, continue in offline mode if connection to  server is broken).
  • A1200 model can be used in net play mode with accuracy < 1.
  • UAE core code updated from WinUAE 2.4.0.
  • Advanced options for tweaking vsync method.
  • Common host options can be specified once in Host.fs-uae config file.
  • Many other fixes and improvements.
Please see the release notes for more information about this release and a detailed list of changes. Also, many thanks to everyone who has been testing the development versions and reported bugs and issues! :)
Re: FS-UAE 1.2 Stable Series
« Reply #1 on: May 08, 2012, 05:32:21 PM »
hi FS - great fix with the $config thing - that is working great.
unfortunately i'm getting crashes when using save-states with HD setups?
I know this was fixed before.....  any thoughts?
update_main_menu
floppy in 0:
update_main_menu
floppy in 0:
save_states_menu_function
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_1.uss
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_2.uss
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_3.uss
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_4.uss
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_5.uss
check /Volumes/GAMING/AMIGA/Amiga Online Big Pack 4/Configs (with Key)/../States/fs-uae-state_6.uss
(and yes, the log ends "suddenly" like that)
« Last Edit: May 08, 2012, 05:35:00 PM by Hungry Horace »
FrodeSolheim
  • PSPUAE Moderator
    • FS-UAE Homepage
« Reply #2 on: May 12, 2012, 01:04:09 PM »
Hi, I've been away this week, so a bit longer response time than usual here...
The crash is unrelated to what was fixed before. The crash has been fixed in the 1.3.x development series, and I'll probably release an updated 1.2.1 with the fix as well.
FrodeSolheim
  • PSPUAE Moderator
    • FS-UAE Homepage
« Reply #3 on: May 13, 2012, 11:24:43 PM »
1.2.1 with fix for save state crash: http://fengestad.no/wp/fs-uae/download
