Author Topic: Amos Pro Download  (Read 12483 times)
caver99
Amos Pro Download
« on: September 04, 2012, 08:11:51 PM »
Sorry about this but i cant seem to find the amos pro download in the download section could any one point me in the right direction please.
Thanks
Graham
Re: Amos Pro Download
« Reply #1 on: September 04, 2012, 10:58:45 PM »
Go to the downloads section
Scroll down to the AMOS Factory List
Click on 'Development (10)'
You will find the following
AMOS Professional 1.0
AMOS Professional 1.12 Update
AMOS Professional 2.0 Update
I'll add a mini install tutorial in a minute when I find the link. :)
Ah, Here it is.
SamuraiCrow gives a good tutorial on installation: In this post -> Here
Read the whole post.
I get the feeling Hungry Horace put together a single V2 full install so there would be no need to do three installs, If i find it I'll put it in the downloads section. HH am I right here or was I just dreaming.
[Edit 05/08/12] The AMOS Professional 2.0 Update download has the disks numbered the wrong way. Disk 3of3 is the AmosPro v2 update and should be installed first. Followed by the Amos compiler use Disks 1of3 & 2of3, Install the compiler from Disk 1of3 and follow the instructions.
« Last Edit: September 06, 2012, 01:14:52 AM by MadAngus »
Q for HH - AMOSPro V2.0 Full
« Reply #2 on: September 05, 2012, 12:27:51 AM »
HH
Did you put together a single V2 full install so there would be no need to do installs of the updates, am I right here or was I just dreaming. :-\
Re: Q for HH - AMOSPro V2.0 Full
« Reply #3 on: September 06, 2012, 12:54:15 PM »
HH
errr... it wasnt me!
I have added it several times to the ClassicWB setup... and i think i uploaded the ADF files here sometime... but i dont recall doing anything like that!!
[Edit by MadAngus] Merged the two topics and removed the link from this one. See the next post for link. Merged due to my mistake, i.e. MadAngus. :-[
boing!
« Last Edit: September 09, 2012, 05:31:43 AM by MadAngus »
« Reply #4 on: September 06, 2012, 12:55:04 PM »
are these the only disks? I am sure i remember AP2 disks.... or maybe i am the one dreaming!
edit:
ta-da!!
http://www.ultimateamiga.co.uk/index.php?action=tpmod;dl=item418
« Last Edit: September 06, 2012, 12:56:49 PM by Hungry Horace »
« Reply #5 on: September 06, 2012, 03:21:31 PM »
Cheers, I download it and take it for a little test drive.
I'll report back. :)
