Author Topic: WinUAE 2.5.1 Released  (Read 7336 times)
« on: December 24, 2012, 10:04:28 PM »
WinUAE 2.5.1 released (22.12.2012)
2.5.0 bugs fixed:
- 1G RTG RAM size was rejected.
- Windows mouse cursor becoming visible in windowed modes.
- 2.4.x and older versions allowed higher Z3/RTG total memory under 32-bit Windows.
- Maprom feature crashed in JIT mode.
- CDTV emulation didn't work.
- Power led state was incorrect.
Other bugs fixed:
- Inserting or ejecting USB game controller or mouse deleted all custom Game Ports panel configurations.
- Fixed DirectDraw fullscreen mode problems if using secondary monitor positioned on left side of primary monitor.
- SCSI emulation read commands returned wrong data if CD/CD image had more than one track.
- Fixed mouse cursor jumping to opposite direction if it was moved to same direction long enough.
- File comments and protection flags wasn't read correctly from _UAEFSDB.___ files. (if non-NTFS drive)
- Windowed mode status bar had gap on Windows Vista classic theme.
- Epson matrix printer emulation red and blue colors were swapped.
- lzh/lha archive MSDOS-style timestamps supported.
New features:
- Directory filesystem full Amiga 1/50s datestamp resolution support, previously resolution was only 1s. (NTFS and archives only)
- Mount drag'n'dropped archive file as a directory harddrive only if removable drive support is enabled, without harddrive
  support attempt to mount as a disk image in DF0:.
Download: WinUAE2510.exe
Source: http://www.winuae.net
