Author Topic: (Bug Discussion) Program will not compile (run) if too many ELSE IF's  (Read 5007 times)
Program will not compile (run) if too many ELSE IF's iirc.
Re: (Bug Discussion) Program will not compile (run) if too many ELSE IF's
« Reply #1 on: December 05, 2012, 08:09:28 PM »
@Hungry Horace
Amos doesn't support the Else If construct, IIRC.  You just have to put in enough EndIf statements to close each If.
« Reply #2 on: December 05, 2012, 08:22:25 PM »
@Hungry Horace
AMOS Pro supports ELSE IF with only one ENDIF against the initial IF,  and I am sure freaks-out if you use too many (i'm talking, 20+ or something, i forget) ... i do use ELSE IF all the time!
I noticed this bug some years ago working on my Bloodwych Editor.
EDIT: just tested and reproduced this bug. The problem only occurs when compiling, not interpreted.... the system GURUs
EDIT 2:  amos program attached. this program will compile. un-comment the 51st ELSE IF and it will no longer compile. (locks-up / freezes)  .... i had even more added and a full GURU occurred.
« Last Edit: December 05, 2012, 08:32:37 PM by Hungry Horace »
