Author Topic: MVolume How to Get the Valor?  (Read 3929 times)
Amiten
  • Amos Coder Since 1990
    • Amiten Software
« on: July 17, 2013, 09:32:00 AM »
Hello,
I want to know when the system have no sound by the inbuilt Mvolume command in amos.
any idea how to know when the system is mute or volume 0  and assign to a variable?
i try with this but get an error
m=Mvolume
do
if m=0 then print "no sound"
loop
Thanks
« Last Edit: July 17, 2013, 09:36:49 AM by Amiten »
AMIGA is a Style of Life
Amiten
    • Amiten Software
Re: MVolume How to Get the Valor?
« Reply #1 on: July 17, 2013, 11:08:51 PM »
Any Help??
« Reply #2 on: July 18, 2013, 09:22:02 AM »
The Amiga has 4 volume controls; one per voice.  To read the current amplitude of a voice you can use the vumeter function.  You cannot use Mvolume as a variable though because it is a command.  It merely sets the music volume.
Amiten
    • Amiten Software
« Reply #3 on: July 18, 2013, 10:40:27 AM »
 :-X :-X :-X :-X :-X :-X
   V0=Vumeter(0)
   V1=Vumeter(1)
   V2=Vumeter(2)
   V3=Vumeter(3)
thanks samuraiCrow you are my hero  ;D ;D
Amiten
    • Amiten Software
« Reply #4 on: July 18, 2013, 01:42:06 PM »
Vumeter only gets the volume from a .med .mod .abk music file but no for the sound samples played by the sam play command  :(
if we do that
sam loop on
sam play 1
Do
V0=Vumeter(0)
locate 10,10:print V0
loop
the valor of V0 always get "0" :(
so any idea how to get the volume valor on a single sound sample??
« Reply #5 on: July 18, 2013, 04:35:35 PM »
Amcaf extension has some extra sound commands, maybe look through the online manual for that?
