Author Topic: PSPUAE 0.72B (4th April 2014)  (Read 10994 times)
« on: April 04, 2014, 01:49:02 PM »
This is a quick fix for CD32 buttons not working.
Also removed cpu's and fpu (useless on PSP).
This is just the EBOOT, drag and drop into pspuae folder overwriting old 0.72 EBOOT.
PSPUAE 0.72B
Re: PSPUAE 0.72B (4th April 2014)
« Reply #1 on: April 04, 2014, 07:53:17 PM »
great fix FOL.
Glad to see my save-states from 072 loading without problem!
(this may inspire me to finish some other WHD CD32 patches)
« Reply #2 on: April 04, 2014, 08:50:06 PM »
great fix FOL.
Have to point out normal fire is bust, seems fixing cd32 buttons bust joy0 fire.
As a work around you will need to use CD32 Red button for fire.
« Reply #3 on: April 06, 2014, 01:20:29 AM »
great fix FOL.
Right after spending hours trying to work around the code thats been altered in the past. I have decided to restore the orignal code and add an enabler (menu option, Enabler CD32 Buttons).
This seems to be an easier and tidier way to do it.
« Reply #4 on: April 07, 2014, 11:19:08 AM »
great fix FOL.
This bug is now solved. There will be an option in menu to set CD32 buttons On or Off.
I wont upload new version, Ill continue working on v0.90.
