Author Topic: command to list drives?  (Read 5976 times)
« on: September 06, 2014, 11:30:17 AM »
HI All
Anyone know how i can get AMOS to list all of the available Hard drives? Even if this needs an extension to do it?
I thought Dev First$ and dev next$ would cover it, but all i seem to get returned is the first assign, no matter what parameters i use.
I could probably parse the output of the 'INFO' command, but that is hardly ideal...
All input welcome!
Re: command to list drives?
« Reply #1 on: September 06, 2014, 03:03:02 PM »
Can't understand why you're not getting results with Dev First$ and Dev Next$.  Works fine for me  ??? .
This is an example that shows how to list Assigns and Drives.  Assigns are easy but there's no simple way to list Drives.  The only quick and easy method I can think up is also in this example.  But that involves the hard-coded Data statement to cover all possibilities.  If there's a limit to how many Floppy-, Hard- and CDROM-Drives are possible on an Amiga, that would probably be your best bet.  I don't know what limits there are so I just chucked in four hard drives and four floppies to show you the method.
Global G_LINES_MAX,G_LINE_COUNT
Proc _INIT_SCREEN
'  List all the assigns:
G_LINE_COUNT=0
Print " "
Proc _CHECK_LINE_COUNT
Under On : Print Pen$(7)+"List Assigns:"+Pen$(5) : Under Off
' Start
D$=Dev First$("")
Repeat
   Print D$
   D$=Dev Next$
Until D$=""
' End
Print
Print Pen$(4)+"Press any key for next example..."+Pen$(5)
Print
Wait Key
'  Check whether the "standard" drive names exist:
G_LINE_COUNT=0
Under On : Print Pen$(7)+"Check 'Standard' Drives:"+Pen$(5) : Under Off
' Start
Restore STD_DRVS
Do
   Read DRV$
   Exit If DRV$=""
   Print DRV$;
   If Drive(DRV$)
      Print " Exists"
   Else
      Print " Does Not Exist"
   End If
Loop
' End
Print
Print
Wait Key
'  Or, list the available drives:
G_LINE_COUNT=0
Under On : Print Pen$(7)+"List 'Standard' Drives:"+Pen$(5) : Under Off
' Start
Restore STD_DRVS
Do
   Read DRV$
   Exit If DRV$=""
   If Drive(DRV$)
      Print DRV$
   End If
Loop
' End
Direct
'  I don't know what the sum total of Amiga drive configurations is.
'  So just expand these data statements to take them all in...
STD_DRVS:
Data "dh0:","dh1:","dh2:","dh3:","df0:","df1:","df2:","df3:",""
Procedure _CHECK_LINE_COUNT
   Inc G_LINE_COUNT
   If(G_LINE_COUNT>G_LINES_MAX)
      Print Pen$(1)+"Press any key to continue listing..."+Pen$(5)
      Wait Key
      G_LINE_COUNT=0
   End If
End Proc
Procedure _INIT_SCREEN
   If Ntsc
      L_YSIZE=200
      G_LINES_MAX=25-4
   Else
      L_YSIZE=256
      G_LINES_MAX=32-4
   End If
   Screen Open 0,640,L_YSIZE,8,Hires
   Palette $0,$AAA,$77,$FFF,$F00,$DD,$AA,$FF3
   Wait Vbl
   Cls 2
   Pen 5 : Paper 2
End Proc
In my usual fashion, I've complicated the code to made the listings look neat and to allow you to see the assigns before they scroll off the screen.  So the essential bits are enclosed in
     ' Start
and
     ' End
comment lines.
It's probably worth putting something simple and easy in as an AMOS V2.xx enhancement (eventually!).  There's probably also some AmigaDOS calls that would do the job and cover any drive combinations (can anyone help with that?) .
Hope this helps ;)
« Reply #2 on: September 06, 2014, 05:16:07 PM »
wow... I think thats longer than my code to read the results of the 'info' command!
the manual says you restrict the DEV command to either assigns or drives only by using "/d" or "/a"  (if i remember right) but everything i did only gave me one listing, of the first assign! (very strange) .... maybe another bug of AMOSpro?
using hard coded options 'dh0:' etc is exactly what i'm trying to avoid, as this has caused a problem sharing my WHDLoad booting program with a friend.
The code i'm using now is this... its a bit nasty but it works, lol
PROCEDURE _GETDRIVES
' ====== this is a program to fill  an array with available drives
' --- output the INFO command to ram:
Exec "C:info >t:infoout"
' ---  load the file, stick it into string
Reserve As Work 1,Object Size("t:infoout")
Bload "t:infoout",1
For B=0 To Length(1)-1
   ALL$=ALL$+Chr$(Peek(Start(1)+B))
Next B
Erase 1
Exec("C:delete t:infout")
' ==== now read each line at a time
For Q=3 To 100
      FISH$=Itemstr$(ALL$,Q,Chr$($A))
   If FISH$="" Then Exit
   For T=1 To Len(FISH$)-3
      If Mid$(FISH$,T,3)=":  " Then Exit
   Next T
   FISH$=Left$(FISH$,T)
   ADRIVE$(F)=FISH$
   F=F+1
   If F>32 Then Exit
   Rem Print FISH$
Next Q
Erase 1
End Proc
« Reply #3 on: September 06, 2014, 07:30:08 PM »
An interesting problem which you now have the solution for :)
I don't think I have ever tried to list all available drives, I have always gone for the hardcoded method - either the drive ID ("df0:") or the disk name ("Games_Vol1:").
« Reply #4 on: September 07, 2014, 10:35:30 AM »
The manual's wrong (again!).  I didn't even check it and haven't got to input / output yet in the docs...
Correct filters are "d:**" for drives and "a:**" for assigns.  So Dev First$("d:**") is what you're after.
Sent from my Lumia 800 using Tapatalk
« Reply #5 on: September 08, 2014, 10:04:11 AM »
It seems a bit silly to call the function Dev First$ as the only two options are to list Assigns or Drives.  Not Devices!
Whilst the "D:" prefix prepares a list of Drives, any other prefix letter prepares a list of Assigns - not just the "A:" shown in the manual.  So I'll put it down as a mild bug at this stage.  I haven't pulled the code apart fully yet as I'll need to map the data storage it uses first (and understand how the lists are created).  So I won't be doing anything with it at the moment.
Is it realistic to expect an Amiga's Devices to be listed?  I don't know AmigaDOS well enough yet.  Can anyone elaborate please?
« Reply #6 on: September 14, 2014, 01:06:21 AM »
I'm no expert on the OS, but Exec Library does have some device commands (AddDevice,RemDevice,OpenDevice and CloseDevice). That seems to imply that devices can be added and removed manually, though I would expect the OS to detect all available devices at startup and add them to an internal list.
Mia
« Reply #7 on: July 19, 2016, 08:26:10 PM »
Frist sorry to for posting on an old thread, but it's still valid.
Thanks Bruce you have saved me so much time, it works.
I did try to debug this issue but it is strange. I have tried the new AGUI library from aminet and it has a file requester that shows both the assigns and the disks - the code it uses is Dev First('') (2 single quotes) so I though if I copy that it will work, but it gave only the disks when run from my code, then when playing with the code in AGUI it suddenly broke and only shows the disks and not the assigns even if a revert to the oriinal code. so it is unpredictable meaning there is a "bug" somewhere, maybe in the internal counter for assigns (*guessing). I  will run Dev First$ twice, first with a:** and then d:** to confirm I have all the assigns and disks.
** Edit
I'm actually not sure if I found a bug, but it's bugging me lol. I think I've made myself a bit of a mess and I'm wasting time on this, spent most of the day on it and it's still not stable so I have to move back to the standard file selector or else I'll never get this finished.
« Last Edit: July 20, 2016, 12:54:59 AM by Mia »
