Author Topic: BOB / SPRITES Priority  (Read 3145 times)
EFX
« on: January 12, 2015, 01:06:34 AM »
Is there a way to manage Sprite Vs BOB priority ?
Is is possible to display a BOB in front of a SPRITE ?
 :P
ebanite
Re: BOB / SPRITES Priority
« Reply #1 on: January 12, 2015, 05:48:52 PM »
yes and no in the same time, you can change priority of sprite over palyfield (even and odd), that means you can draw bob over the sprite, but the sprite is under the graphics too...
if you feeling great, you are great
