Author Topic: Proposed Bounty: Support for Modular Animation system! My Spriter Prototype  (Read 5794 times)
MichaelVParent
Hi fellow Amos users.  I'm donating my fully functional prototype of Spriter (runs on Windows PC only) to anyone who wants to use it. It's fully functional and perfect for creating modular animations (animating a character or effect made from multiple sprites or separate image blits).
Here is a series of tutorial vids explaining how to use it: https://www.youtube.com/watch?v=IalClLASot4&list=PL932376385F1A6991
The full, unlocked version can be downloaded from here: http://www.holymonkeystudio.com/spriterproto/SpriterPrototype.zip
I'll report back here with example files/animations in the near future.
Goal for Bounty?
1) A program that loads all the images used in the Spriter animation file (they'd just be iff images in a folder) and then adds them to an amos sprite or bob bank.
2) The program would then also convert the animation data from the Spriter file into the actual amal/amos code as ASCII format which can then be copied and pasted right into Amos.
3) Any images from a folder called "sprite" would be added to a sprite bank and used be drawn as sprites, while any images from a folder called "blits" would be added to a bob bank and drawn as blits. (using powerbobs extension)
Looking forward to thoughts and feedback.
cheers.
MichaelVParent
Hi again everyone.
Here is a new video showing my example file:
https://www.youtube.com/watch?v=8EoKQEtNq60
And the actual example file can be loaded from here: www.holymonkeystudio.com/ProtoSpriterExample.zip
Goal for Bounty?
These should be feasible, but for me it will be a limitiation of time-frame, because I dont have much free at the moment!
Register me as 'interested' but if i get beaten to it, i wont be too upset ;)
MichaelVParent
Awesome.  I'm glad you're interested Hungry Horace.
Anyone else have the time and interest? Maybe a collaboration?
Cheers,
Mike
