Author Topic: PS Vita PSM Unity exploit Discussion  (Read 14376 times)
Re: PS Vita PSM Unity exploit Discussion
« Reply #15 on: September 23, 2015, 06:21:31 PM »
I was newbie last year.
http://wololo.net/talk/viewtopic.php?f=65&t=43262
If I remember you have problem with QCMA, if you need a help with that I can help too.
When you set up QCMA all the rest is a piece of cake.
I cant use QCMA, it keeps asking me to update. I cant use anything without updating.
EDIT:- Got it to transfer, but Im screwed now as nothing needs updating game wise. So I cant even download anything.
EDIT2:- Got it, :). Be nice if they said you had to click the failed update, ;).
Now need to work out what I can do with it.
EDIT3:- Just downloading unity stuff. Anyway to block the update message or spoof 3.52?
Update blocker doesn't work.
EDIT4:- Spent 8 hours on this, there is stuff missing from devkit or sdk, not sure which.
Im missing vita-elf-create and arm-vita-eabi-gcc. I cant find them anywhere, I have spent an hour searching, :(.
Its frustrating as Im almost there.
« Last Edit: September 24, 2015, 12:32:59 AM by FOL »
Raul
« Reply #16 on: September 24, 2015, 06:07:09 AM »
I will ask for help or look for answer.
You really made progress.
I never thought that I could have full speed Amiga on portable device with a joystick :)
« Reply #17 on: September 24, 2015, 07:59:31 PM »
Give up, turned on vita today and it said it did a system update (on its own). PSM Unity and its saying its not licensed now. I tried doing PSM steps and nothing. ,:(. Checked version and it says 3.51, really confused.
EDIT:- I tried PSM+ renew key option, seems to have fixed it. Is it me or is the PSP HB scene a mess at the moment. Theres no nice guide's like there used to be.
« Last Edit: September 25, 2015, 10:52:07 AM by FOL »
« Reply #18 on: September 25, 2015, 10:52:57 AM »
Right, when I get some time, Ill sort out my linux setup and compile the toolchain myself.
Hopefully that will give better results.
Raul
« Reply #19 on: September 26, 2015, 09:44:59 AM »
http://wololo.net/2015/06/13/vita-sdk-making-steady-progress/
It's from June so it should be in a better state now.
Vita Toolchain
https://bitbucket.org/cirne/vita-toolchain/src
This prompt to update is not important, it's the way Vita tell you something is wrong with the licence (PSM+ renew licence then)
PS Vita scene is mess because to many things are done at short time.
http://hackinformer.com/forum/thread-459.html (tutorials)
