Author Topic: Problem with the AMOS configuration and increasing editor text buffer  (Read 10223 times)
Re: Problem with the AMOS configuration and increasing editor text buffer
« Reply #15 on: November 05, 2015, 06:18:14 PM »
Yes.
« Reply #16 on: November 06, 2015, 06:18:08 PM »
Hungry Horace says he uses AMCAF without any problems.  Just avoid some of the extra graphics capabilities like splinters, rainbows and such.  Hungry Horace could give you a better answer as he's using it.
He's also done some work on the Power Bobs extension (removed the nag screen) so you might want to look at that too (thanks Hungry Horace - keep it up!).
I'm hoping  that some people might pick up the initial work I did on the extensions with a view to sorting out the good from the bad and fixing them up.  Upgrading to the 2.xx library standards would also be worthwhile.  It's just too much for me to take on until my current workload is out of the way.  Any offers people?
the re-sourcing work you did was invaluable!
What would the 2.xx fixes entail?  I must confess it's not really my expertise....
FYI AMCAF is a 'must have' extension for me every time.... although now you've mentioned fixes i might look into the bug with Ext Joy 3 or 4  (i forget which one it is) which meant i always had to use *another* extension for one of the extra inputs!!
It has so many 'same as amos but fast maths' commands, it's really invaluable.
I started a new job recently and some home improvement which I confess has meant i havent really had my spare 'amiga time' to play around with stuff, but believe me when i say its never far away!!
