Author Topic: simple enhancements  (Read 5511 times)
simple enhancements
« on: March 11, 2016, 01:39:16 PM »
I have had a re-think about how to approach my editor, Book of Skulls, BEXT2 and the general re-sourcing efforts.
In order to achieve the end-goal i want, it's seeming quite likely that a re-compiled source (thank's to BruceUncle) is more likely to achieve what i want in terms of game extras for Book of Skulls, and ultimately BEXT2.
I will adapt my editor to read in as much data as possible from the original games, but i am going to have to draw the line somewhere in terms of what hacks it adds into the game. (e.g. adding in all my new communication elements has proved a nightmare)
As such, i'm thinking both BW and BEXT could have 'enhanced' versions, with a few extra niceity's thrown in, and my editor could simply support those versions - for example, having more than 8 colours in each large monster.
I'll then only need a small edit to add in some 'Book of Skulls' specific elements. (this is relying on some nicely compilable code from Bruce!)
Perhaps any of the game players (madmunky and others!) could have a think about what simple and minor enhancements could be brought to the games, using what is already there.
At the moment, i'm working on a new avart set for BEXT 2, so that those 2 or 3 characters who never got used (Ulrich, Eleanor, Hengist) can have their heads used as recruitable monsters.
As you can see (attached) Hengist wasnt re-colourable before.... this is now fixed :)
I'm also thinking of things like 'data block for centrally placed chracters' (like zendick)  which can be easily edited, rather than them relying on specific code.
Re: simple enhancements
« Reply #1 on: March 12, 2016, 10:29:20 AM »
Maybe a list is needed for the enhancements here :)
I would welcome addiontal suggestions!!
BW
Add the "drop object" code from BEXT
BEXT
Improved avatars for additional  monster recruitment
BOTH
Object required to complete game?
New triggers or switch actions (please suggest!!)
No spells offered if spell book is full
Data block for characters who stand in the middle position
Improved communications code from a data-block (eg more names etc)
Adapt arc bolt machine code to fire any spell
« Reply #2 on: March 13, 2016, 11:01:12 AM »
Eek! (And probably Ook!)  You can't do that...  Yet.
Read the post here to see why.  ;)
So have fun with the ideas flow but you've some work to do before you can put them into practice.
« Reply #3 on: March 13, 2016, 12:30:20 PM »
Unless I do the same as my hacks and add new code at the end... Being sure to add NOPs and retain the same data lengths where any JSRs are inserted and original code relocated ;)
I'd rather help make the Asm file compilable, but some of your more resource heavy posts go a bit over my head BruceUncle!
