Author Topic: Cant fit in current screen !  (Read 2565 times)
Amiga Forever
« on: March 15, 2016, 01:36:36 PM »
I am trying get back in Amos :)
I got a problem as I got title screen that is 320 x 256 with 32 colours then I open the screen open 0, 320,256,32,lowres then I get error saying cant fit in the current screen!
Here the code of it...
Load IFF "TitileScreen.iff"
get sprite palette
Screen Display 0,320,256,32,lowres
Flash off: Curs off
Repeat
          Wait VBL
until Keystate(64)
Screen close 0
What am I doing wrong!?
[/code]
« Last Edit: March 15, 2016, 01:41:56 PM by Amiga Forever »
Re: Cant fit in current screen !
« Reply #1 on: March 15, 2016, 04:43:07 PM »
Try opening the screen first?
Amiga Forever
« Reply #2 on: March 15, 2016, 04:58:04 PM »
I did this one
Screen open 1,320,256,32,lowres
Load IFF "TitleScreen.IFF"
Wait Vbl
wait key
the error I got was saying "CANT Fit in current screen" even thought it is same size as IFF Picture that I have load!
[/code]
« Last Edit: March 15, 2016, 05:24:23 PM by Amiga Forever »
« Reply #3 on: March 15, 2016, 10:47:20 PM »
Load iff "file",1
Try adding screen number at the end like that ^^
If you do, you may not even need to pre open the screen
