Author Topic: Amos Launcher  (Read 12598 times)
Mikket
Amos Launcher
« on: April 28, 2016, 06:00:48 AM »
Hi.
I made this launcher based on the great work of Mequa-Wilen-Arosteam.
I hope it works.
http://itek.fi/Amos_Launcher/
Mikko
Re: Amos Launcher
« Reply #1 on: June 18, 2016, 10:22:14 AM »
Hi.
I hope it works.
Mikko
Very nice, I love it.
Devine
Re: Amos Launcher
« Reply #2 on: October 18, 2016, 10:07:21 AM »
This looks nice,thanks :)
When I launch the launcher I select Amos pro. I then get a UAE screen, see screenshot. What should I do here? When I select start I get a screen stating no bootable media found.
« Last Edit: October 18, 2016, 10:09:53 AM by Devine »
Re: Amos Launcher
« Reply #3 on: October 19, 2016, 02:28:15 PM »
What HDF are you using?  I can tell you're using the AROS Kickstart but you still need to boot AROS to run Amos under.
Mikket
Re: Amos Launcher
« Reply #4 on: July 07, 2022, 09:12:50 AM »
My quick support team has fixed the Launcher :). Should work now as a portable.
There's also ASM-One assembler access from the user menu.
Couple of very simple ASM examples included.  The machine language should
be written as an object file from the ASM One.
Launcher is using aros roms, so users can make legal portable "PC" games also.
Mikko
« Last Edit: July 07, 2022, 09:15:54 AM by Mikket »
