Author Topic: No hash key when running AmosPro in WinUAE  (Read 5298 times)
NeilIves
« on: August 30, 2016, 05:39:40 PM »
Hi folks!
I'm trying to get back into AmosPro using WinUAE on a Windows 10 machine, (UK Keyboard) . I've discovered that the key marked Hash does not print a hash in the Amos editor window, just a vertical bar. Can you tell me how to get around this? Copy and paste from a text document will not work! Many thanks!
Neil Ives
Mia
Re: No hash key when running AmosPro in WinUAE
« Reply #1 on: August 31, 2016, 03:54:52 AM »
 :o mine is sometimes the @ key or ' or ` or ~
« Reply #2 on: September 01, 2016, 06:40:43 PM »
What keymap is selected in your Amiga Workbench settings?  If you're using a ready-made HDF or ADF set, you may have to switch keymaps in the preferences.
