Author Topic: FD Extension  (Read 4245 times)
Mia
FD Extension
« on: September 16, 2016, 04:27:07 AM »
Inside the GUI Extension "Tools" folder there is the FD Extension - I wanted to take a look to see if I could work on the BSD library but found that the FDBuilder is looking for a file FDLib.prefs in the FD: folder but there is no such file - creating a blank file makes FDBuilder quit?
Re: FD Extension
« Reply #1 on: September 17, 2016, 04:59:55 PM »
The development version of a library download should have an FD file.  If you mean BSDSocket.library, it is a per-opener library so it might not.
Mia
Re: FD Extension
« Reply #2 on: September 18, 2016, 03:43:46 AM »
the fd for the bsd library is in the fd folder of the fd extension - i saw it mentioned on an old post recording amos:
http://www.amiworld.it/news/amos_upgrade_eng.html#A05
the FDBuilder application does not run because of the missing preferences file, so I'm unable to create the FDExtension for AMOS - I believe the FDBuilder has a check list of FD's you want to include, and you choose the extension number you want then configure amos.
I don't think it does anything extra than using LibCall directly but it's neater and you don't have to reference all the dreg/areg - I monitored it using SnoopDos - it was looking for the FDLib.prefs file.
