Author Topic: ASCII PLAIN TEXT IMPORT TO AMOS  (Read 2802 times)
Amiten
  • Amos Coder Since 1990
    • Amiten Software
« on: October 12, 2016, 09:07:10 PM »
Hi dudes,
any help about how to import "TEXT" to Amos editor?  I try with the menu Project merge ASCII option and the text from a plain.txt file comes but in a UPPER CASE mode so I have to write again each letter in Lowcase :o is any way / extension or something for import the texts to Amos without these Trouble??
Thanks in advance
Johnny
AMIGA is a Style of Life
Mia
Re: ASCII PLAIN TEXT IMPORT TO AMOS
« Reply #1 on: October 12, 2016, 10:14:07 PM »
when you merge, the editor is parsing the plain text into amos code.
the way i got around it was by manually adding an ' character at the beginning of each line to make the text a rem comment so it merges it as it is and doesn't try to parse the line into code.
hope thats what you need
Amiten
    • Amiten Software
« Reply #2 on: October 13, 2016, 01:00:37 PM »
Hi MIA!!  you are the MAN!   ;)  help 100% for me too. thank you
All the best!
Johnny
« Last Edit: October 13, 2016, 01:04:30 PM by Amiten »
