Author Topic: Tutorial on installing AMOS Pro 2.x to HD?  (Read 7395 times)
0 Members and 5 Guests are viewing this topic.
fstltna
  • Indie game dev
  • Gender: Female
  • Long time Amiga user and indie game dev.
    • Amiga City
« on: June 25, 2017, 08:39:24 AM »
The other post on this subject doesn't really say much and is quite old. Can someone point me to a tutorial on installing AMOS Pro to my HD? I don't see any installer routines on the disks. Any pointers? I'm interested in using AMOS Pro on my next project...
--- https://AmigaCity.xyz - Portal for the Amiga with over 2,500 files to download
Re: Tutorial on installing AMOS Pro 2.x to HD?
« Reply #1 on: June 25, 2017, 05:26:29 PM »
You should be able to just copy all the files to a single folder and set up the assigns with something similar to:
;BEGIN AMOS Professional
Assign AMOSPro: System:Programs/AMOS/AMOS_Pro/ >nil:
Assign AMOSPro_System: AMOSPro: >nil:
Assign AMOSPro_Accessories: AMOSPro:Accessories >nil:
Assign AMOSPro_Tutorial: AMOSPro:Tutorial >nil:
Assign AMOSPro_Examples: AMOSPro:Examples >nil:
Assign AMOSPro_Productivity1: AMOSPro:Productivity1 >nil:
Assign AMOSPro_Productivity2: AMOSPro:Productivity2 >nil:
Assign AMOSPro_Compiler: AMOSPro:Compiler >nil:
Assign AMOSPro_Extras: AMOSPro:Extras >nil
;END AMOS Professional
in this instance, i have placed everything in the folder: "System:Programs/AMOS/AMOS_Pro/"  (see line one)
here is a copy of my folder for it, if you want:
http://www.ultimateamiga.co.uk/HostedProjects/AMOSFactory/AMOS_Pro.zip
I cant guarentee this will work, but dont see any reason why it shouldnt!!!
fstltna
  • Indie game dev
  • Gender: Female
    • Amiga City
« Reply #2 on: June 25, 2017, 07:56:55 PM »
Thanks! I'll give that a try...
Amiten
  • Amos Coder Since 1990
    • Amiten Software
« Reply #3 on: August 03, 2017, 04:49:30 PM »
Do you know if you can watch 640x512 interlace screen correct with this Amos pro instalation Horace?  thank you
AMIGA is a Style of Life
Amiten
    • Amiten Software
« Reply #4 on: August 03, 2017, 04:50:30 PM »
You want to do it from Scratch?¿  I mean installing each 6 floppy or Adf Amos pro instalation¿  Real Amiga or emulation ¿? thank you
« Reply #5 on: August 08, 2017, 09:41:47 AM »
People, people!  This just isn't good enough.
AMOS Pro, and especially the AMOS Compiler, have to be correctly installed.  It's not just a matter of copying files and chucking some assigns in:
  • The editor config file has to be updated to add the compiler menu items into it.
  • The interpreter config file has to be updated to tell AMOS where the APSystem directory is.  With this info alone, AMOS does all those assigns for you!
  • The compiler config file has to be updated.
  • Important files have to be copied to the C:, LIBS: and FONTS: assigns.
The only problems with the original install disks is the reporting of available HDD space.  There are two scenarios:
On a real Amiga, you'll need to install to a partition where the number_of_free_blocks multiplied by the block_size doesn't exceed an unsigned long.  In numbers, that means a partition no larger than just under 4.3Gb for a block size of 512 bytes.  2.15Gb for a block size of 256 bytes, and so on.
If you're using WINUAE, the problem will only arise if you're using a directory as a 'soft' hard drive for your system drive, where your PC HDD may well be one or two terabytes or even more!  To fix this follow these instructions:
  • Add an *.hdf file of around 10 Mb to your installation.
  • Using the *.adf images attached to this post in a zip, install AMOS Pro to that disk, NOT to your system disk.  Then install the Compiler to that same *.hdf disk.
  • You'll end up with a directory called AMOS_Pro on that drive.  All the stuff for C:, LIBS: and FONTS: will end up on your system drive.
  • Now copy the entire contents of that AMOS_Pro directory to a directory of the same name your system drive.
  • You can now remove the *.hdf file as a drive.
  • Before running AMOS, go into the AMOS_Pro/APSystem directory from workbench and find the Locate_APSystem icon and double-click it.  This adds the necessary update to the interpreter config file.
  • Job done!  Works every time.
I'm currently putting together disk sets to do clean installs of both AMOS 2.0 and AMOS 2.1 beta without all this hassle.  I hope I may be able to get those out before I have to go into hospital...
In the meantime, you may also be interested in a work around for the Dfree call that causes this problem.  This will give free space in Mb for partitions up to a couple of terabytes (more or less depending on the block size you're using:
A5_BUFFER=$4F2
Screen Open 1,640,256,2,Hires
Palette $0,$EEE
Dir$="dh0:"
' Lazy way to get AMOS to do the dos call:
X=Dfree
A=Leek(Areg(5)+A5_BUFFER)
' The InfoData structure has to be longword aligned, so this
' matches what the Dfree call does to achieve that:
Add A,4
Ror.l 2,A
Rol.l 2,A : Rem A --> InfoData structure returned by Info() call
D_BLOCKS=Leek(A+12) : Rem Total Blocks
D_USED=Leek(A+16) : Rem   Used Blocks
D_BSIZE=Leek(A+20) : Rem  Block Size in Bytes
Locate 0,5
Print "Total Blocks: ";Hex$(D_BLOCKS,8),D_BLOCKS
Print " Used Blocks: ";Hex$(D_USED,8),D_USED
Print "  Block Size: ";Hex$(D_BSIZE,8),D_BSIZE
D_DIV=$100000/D_BSIZE
D_FREE=(D_BLOCKS-D_USED)/D_DIV
Print Using "     Mb Free: ###,###";D_FREE
Direct
Attached is a set of *.adf disk images of the original AMOS Pro and Compiler disks with correct names.
